Flywheel question
xXChevyXx
Wisconsin
On my revo I can spin the flywheel easily without it turning over the motor. I know it's not supposed to do that and what would be the cause?
take the backplate off to see about the pin, and hold the shaft the clutchbell is over and try spin the flywheel to see if thats loose.
Nut Loose, they make a tool that screws into glow plg hole that when you roll it over the piston hits it to let you torque nut. I put a bit of lock tite before I torque.
Yuck!...Don't stick anything down the plug hole, just hold the flywheel with some pliers and tighten the nut.
