Fixing to order my savage x 4.6 and.....
FORDSVTTHUNDER
RCTalk Qualifier
North East Alabama
I would like any recommendations for other items I may need ASAP . I'm getting the wheelie bar, buying fuel local, the rtr x 4.6 and I'm wanting to know what after run oil to buy. Ordering from amainhobbies. Thanks.
You can use WD40 for after run oil but i have found it tends to shorten glow plug life. I usually use fuel that has rust inhibitors blended into it so I don't use after run oil.
I have a fleet of ten which includes 7 nitros and I use a quart of marvel mystery oil that I put in a 250cc fuel bottle. I then apply it to the carb and to the glow plug hole but I clean those areas first.
I use the Hobbico and have no problems starting up. I first started using WD-40 like traxxas recommended, but found out it was really hard to start.
Yeh mine was hard to start on wd40 too. Stopped using that after I realized it was causing a problem
