fixing the basecamp
majin
My love for RC: Intact. My RC cars: Not so much
kentucky
  3. Crawling
  4. Scale Builder
my sons been seeing me work on dang near every truck EXCEPT his basecamp. weve gone on 2 trails and hes had to sue other trucks but keeps on about missing his camp.
so i ordered him the
Treal SCX10 III Front Axle CNC Aluminum 7075 Front Portal Axles for Axial SCX10 3 1/10 Scale AR45 Axles
and the driveshafts to repair it.
i also downloaded and printed out a skid plate adapter for the
XPT3 LCG Transmission - RawSilver
and plan on swapping out the transmission while I'm under the hood.
the camp is already sop danged capable, this can only help as far as i can see.
but more than that I'm tired of looking at the trans sitting here waiting on a build that hasnt started
The NEW XPT3 LCG Transmission from REEFS! Designed in house from the ground up to provide the best performance and durability possible. Details:
Machined Aluminum case,
Hardened Steel Gears, Titanium output shafts, forward motor mounting, and 48 pitch gears.
Easy to set gear mesh with a cover to help keep the elements out.
Weight: 75g
Pinion size 11t-20t 48p
Trans ratio 6.75:1-12.27:1
FDR straight axle 25.31:1-46.02:1
FDR Axial portal axles 48.52:1-88.21:1
FDR Vanquish F10 portal axles 35.44:1-64.43:1
*FDR = Final Drive Ratio
Dimensions:
H: 38mm
L: Case 24mm/ Shaft End to End 41mm
W: 54mm
Recommended: 11t pinion for straight axles, and 14t pinion for portal axles. May vary based on rig.
Weight: 75g
Dimensions:
H: 38mm
W: 54mm
Nice! You should teach him how to fix his rig so he can get that aspect of rc. Or at least that's me, do what you wish 🤷‍♂️
i hear and agree!! hes helped me with the repairs each time,
most of the things done have been cause i wanted to lol, he breaks the axles consistantly so I'm throwing aluminum to keep that panhard mount link intact.
It does look like he skips leg day. 🫠🙃
Stock driveshafts are almost always the first thing I blow up on all my crawlers. It always amazes me to see people still rocking plastic after adding weight to their build. Makes me wonder what the heck I’m doing wrong lol.
I've gone through many ring and pinions, broke bolts off in lockers, had tge metal axle to the wheels been replaced. All of that was on my scx10ii 2000 xj. I replaced tge stock axles once as it came apart and I lost the metal part and they were developing play after years of abuse. The factory axial wb8 are amazing.
Dang! I have blown driveshafts out of every single solid axle truck I’ve owned. I think it’s because I primarily drive them on rocks and like to bind them up and throttle out of odd positions.
