Build Thread first front end rebuild
ksrichard
lemoyne pa
so i wrecked pretty bad. need to replace upper and lower arms
bulkheads chassis braces skid plate shocks and bellcrank posts. may need a little
help on how to realine front end..
Tmaxx 2.5. What size screws do i need to attach bellcrank
Posts to the frame?
Metric 3x10mm
---------- Post added at 11:55 AM ---------- Previous post was at 11:54 AM ----------
You May can use 3x12mm also. All the screws on your tmaxx are all 3mm threads they just vary in length.
Can you align the wheels without a camber guage? Can i make one? Looking for the cheapest way
To adjust toe and camber.
I just use a tape measure for toe and a carpenters angle for camber. Mostly i just eyeball it honestly.
---------- Post added at 3:01 PM ---------- Previous post was at 2:57 PM ----------
Unless your a professional racer you really dont need to be petty with fine tuning of camber. As long as your rig will go in a straight line when you let the wheel go then your fine. Just my opinion.
Thanks. I'm getting "tail wag" slightly at high speeds. Has to be slowing me down.I just want to get the best
performance i can.
Definatly want RPM in rear as well. Just waiting till i bust factory arms.
There is a chance you will never bust the factory's. just build up you funds and upgrade them anyways. I love my tru tracks.
Sweet. You are a great help.. Thanks. Time to make some noise with rebuilt rig.
:D:D
Went to a construction site, great place to do some bashing. Seems rebuild good. Took
Both tmaxx's. RPM arms really take abuse. The one is still getting hot. Hafta take out motor
And get it to the shop. The other cooled by a good tune. Little rich, its spitting fuel out exhust.
Ill lean a little. Anyway this time nothing broke!!!! Lotta fun
