Factory Mesh and Center driveshaft movements
psychoswat
South Australia
Hi
would like to know if the mesh is too tight from factory, still running the pin system.
Also, the center drive shaft seems to have a bit of play in it, is it normal?
thanks in advance!
seems a little tight for what i normally do but i can't feel it so I'm not gonna say it wont work the X-Maxx mesh system works pretty well easy and but if you have a gearing ratio that the mount doesn't have slots for you can just remove the pins and it turns into a normal sliding mount
factory gear mesh looks to tight to me. I use the old paper trick . , never had any failures when I set gear me that way. drive shaft movement looks ok its you doing the in n out of it..
Yea it’s pretty dumb proof wonder why other rc weren’t using the same system. Is it the bottom 4 screws that I can loosen when setting the mesh without the pins ?
Yep planning to set the gear using the paper trick see if it’s any different from the factory settings. I noticed the splines from the driveshaft was showing when I checked the pinion set screw the other day then drove it around a few days and check it again with the mesh, and saw that part moved so I poked it around 😆 and found out that it moves. Was just worried about getting any sand or dirt into those splines
yea its the those screws but it can be pretty tricky at times i like to put zipties over around the brace and over the motor to stop it from falling out when i put the mount screws back in
