EZWING 35A Crawler ESC
Oldblue
I got it installed in my home made crawler- but I want to program it so reverse has more power- it hardly moves in reverse- now the manual talks about the green light flashes for N times - then enter the N item - press SET key to chose the value, the flash times of RED LED means the serial number of the value (1 times means value 1st value ...etc)
OK now I'm lost any one explain to me what N times means? Thanks the value I need is PROGRAMMABLE VALUE #3 thanks in advance
N just refers to how many times it blinks. Usually during setup you will see the light blink once, pause, blink twice, pause, blink 3 times pause, etc. After you see the 3 blink, you press the button to alter the setting for value 3.
ok got it thanks I'll give it a go
