Joebegsmaxx2.5
- Thread starter
- #21
The resonator pipe will work..But
if your going to put the 3.3 into the 2.5 truck? There's a couple things to watch out for bud.. First change the slipper clutch to the 3.3 slipper clutch. The one from the revo or Tmaxx same one. Much better then the plate slipper clutch of the 2.5. Also you should keep you spur gear plastic. If you run metal you will rip your tranns apart. Spur gears are plastic for a reason. The drive train of the 2.5 really wasn't designed to run the 3.3.. which has more low end tourqe then the 2.5. You can run it but keep a eye on your axles and center shafts and your diffs. Or upgrade them to CVD's. You can also fit the 3.3 diffs in the new 2.5 grey bulk heads. Not in the black ones.. the tranns might not like the tourqe of the 3.3 either. Just a heads up. You could get better gears then the plastic ones in the 2.5 tranns.. got any questions don't hesitate to ask.. hope it works out for ya.. one more thing what type of fuel are you using??![]()
I'm running bones brew 30/10 on my 2.5 currentlyThe resonator pipe will work..But
