exhaust mount
mpatterson136
I keep losing the small exhaust mount bolt that holds my pipe on to the mount I'm using a spring mounted header for flex but now i can't keep the pipe on its mount could i soider it or does anybody know a fix for this:(
try using a small set screw in the hole that the pipe hanger goes through so it stays there. aftermarket pipes sometimes come with them like the ths racing pipe.
Take out the small set screw and replace with a cap head screw. Then you can get more torque down on it. Using gel locktite helps keep it from loosening up as well.
