Exhaust Baffle
SSievers08
Hastings Nebraska
  1. Racing
So my brother in law has an STR also. His is completely stock except for a higher flow air filter and a set of aluminum wheels. Well he doesn't do any of the work to his car, I do it all. He hasn't had the car out sense last summer so he brought it over so I could go over it and get its throat cleared and ready to go for this spring and summer. In the process of getting everything cleaned up I took off the pipe (which as stated is the stock plastic Redcat pipe) and noticed a piece that could come out. I started digging online about it and decided from what I had read to remove it. And holy poop did that little VX .16 ever clear its throat. On top of an increase to top end power (once I made it a little richer due to the lack of the baffle) it sounded like a whole new animal.
So for those new to the site wondering if you should remove it or not. I'd say give it a go. If anything you can always throw it back in if you don't like it or notice any negative effects.
I think guys used to do that back in the day on the savage. It had a stock 2 chamber plastic pipe that you could take apart... I think. 2 chamber pipes tend to be tuned more for putting out higher torque in the upper RPM range whereas a single chamber (no baffle) tends to be more of a lower RPM torque pipe.
This is the pipe. Took photos in order to show how it came apart and where the baffle was. (poop camera warning)
