Hello anyone I sure could use some help
What I'm working on is my Exceed Infinity nitro truck I'm up grading the front and rear suspension arms and the frame with aluminum parts I got the back suspension back together just fine my problem is the front suspension arm pin hsp part # 02036 is to short its sopose to slide through the suspension arm Mount hsp part # 02022 and the suspension arm part # 08005 those are fine when I put those together the pin is long enough to put the E-Clip on to hold those parts in place now here's my problem there one more part that has to slide onto that pin part # 02017 suspension arm Brace now the pin is to short to put the E-Clips on to hold those parts in place. I measured the new parts with the old ones and there the same dimensions. Everything should go back together like it was l feel so dumb that I can't figure this out The back went together great the back pins are 53 mm that's longer than the front because it slides through the back Bumper and the front pins are 43 mm and it doesn't slide through the front Bumper. I don't have a Diagram of how things go a person would think back and front would be the same the frame has a notch were the brace slides into just like the back does. Any help would be greatly appreciated Thank you!!!!
