esc vxl-3 from velineon
dmmcm
usa
The bullet connecters came out of my esc, can they be resoldered in or is this time for a new one?
They can be resoldered. Did the wires come loose from the ESC, or did the connectors just come loose from the end of the wires? Either way, you could always install a deans ultra or a bigger connector if you wanted to. If you decide it's time for a new one, I might be able to take that one off your hands.
If its the blue, yellow or white, just push them back in. They are exactly that.. Connectors, if its the black or red then start soldering....
Well the whole bullet connector came out of the ESC on the yellow and the white wire,to solder it i will have to take it apart right?I thought it was just the wire came out till i checked it a little closer and seen it was the bullet connector end that had broke that free from the ESC.
