- In my recliner
- Flying
You've done a lot of unnecessary things to it already. What you describe is exactly the symptom of being too lean on the LSN.pugs2300 said:when i first start it up it runs great...probably for the first 5 minutes or something it has great power and response...it will flip on command...
but after a few minutes, like after it gets good and warm, it will just quit...
If it gives you great takeoff as soon as you start it, it's too lean. It should warm up to running temp first.
If it quits when it warms up, it's because it's too lean on the LSN.
A simple twist with a small screwdriver would have solved your problem.
