kx250ryder
I recently overhauled my entire car (9.5 Pro), and I didn't think to check my fuel line lengths when I put new line on. So now, when I run the car there is a substantial difference in temperatures from beginning of a tank to the end 220 at start up to 270 at end (before the engine totally leans out). I have two theories on this:
1.) My jetting is off. I read somewhere that certain jetting conditions can cause the engine to get progressively hotter as the run goes on. But I can't remember which needle would cause this issue.
2.) My fuel pressure line is too short/long. I have inquired about this before, and couldn't get a straight answer about this. I figured that by shortening the line, this would allow the engine to pressurize the tank easier as the fuel level gets lower.
Any suggestions? Its kinda frustrating when my engine is lugging so bad that the car hardly leaves the ground over a jump at the beginning of a tank, yet is going like 25 feet off of the same jump towards the end of a tank, and almost blowing up from being too lean. Or is this common? I guess I should ask if everyone else has to adjust their carb during the SAME tank of fuel.
