truq
have a savagex with Nosram 30Monster (=LRP spec2) Last weekend i went to a new place to race with my friends, flat fast track... during the day suddenly the engine begun to idle crappy and was impossible to tune perfect... cleaned the carb but noticed also the rotostart hardly turned it over... however i made the racing day with not-so-perfect idle, off-idle and power.
today i tore the engine apart, no visible cracks, leaks etc.. but at TDC, without cyl-head, the engine is very tight... actually the piston has a dead spot at tdc where it is stuck and i can turn the flywheel many degrees without any movement on piston... what is this situation? was i running too lean long periods of WOT and ruined the piston-cyl... the engine has seen only some 1/2 gallons of 25% quality blend, and worked and tuned perfect this far.
help and ideas are greatly appreciated, since i need to outrun my buddies next weekend
thanks.
thanks.
