Now here's a doozy!
We just broke in my RS4 3 Type SS engine and we were having some trouble getting the clutch to shift. To make matters worse, the car is temporarily out of commision due to starting problems. We've already gone thru 4 glo plugs, 6-7 tanks of 20% nitro fuel. and the left front dogbone keeps coming out. The last time the dogbone came out, i had turned the engine off and tilted the car to try to get the dogbone back in place. When we tried to start it again, it took much of our patience, we removed the glo plug, found fuel in the plug, and about an ounce or two of fuel in the engine itself. I turned the car upside down to remove those ounces of fuel. We tried to get the engine as empty as possible, and still it won't start. We've checked the glo plugs, we've cleaned the air filter, we gave it some throttle while we were trying to start the damn thing. nothing works! if this sounds confusing, you're not alone.
If you can translate this passage into plain English, you might be able to help me! Any suggestions? And no, I'm not taking the engine apart!
Thanks so much!
Gthang
Thanks so much!
Gthang
