savagewild
my wasp28 has been broken in with 6 tanks of hpi 20% nitro fuel following the directions. it isnt supposed to run over 250f on the temp. when I'm running in first gear the engine runs hot (around 265f) then when i get up to second or third gear it runs about 240-250f. how do i fix this & what do i adjust to fix the engine where is stays close to the 250 range. dont know if the tires will have affected the engine but I'm running 40 size tires now instead of stock. how many rounds open should the low needle & high needle be from closed ? next thing what would be the best tuned pipe for the wasp28 for both speed & performance ? I'm still using the stock pipe that was on the hpi25 stock engine. also what is the best air filter for the wasp28 ? only 3 parts on my savage is still stock (pipe, air filter & arms) and i plan on leaving the arms stock.
