i had a similar problem with my rossi, renegade. thanks for the pm. the problem was traced to 2 sources:
1. the instuctions are incorrect pretaining to the LSN. My engine would start but then slowly run faster and faster and move while at idle. also would die and not restart once it got hot. I had to richen the LSN almost 2 complete turns before i fixed the problem. Start riching out the LSN 1/32 of a turn at a time, and driving the car AT LEAST 1 MINUTE before adjusting it again. I know this sounds like a HSN problem, but it isnt, it relates to the LSN on this engine.
2. The other problem i noticed, was that the the clutch that comes with the NTC3 was too soft and would engage at idle. The rossi likes to idle a little bit higher than most engines, and therefore needs either tighter clutch springs, or shaved shoes. I chose to shave the clutch shoes approx 1/8 of an inch. Not only did this allow the car to idle smoothly, but it gave it more punch off the line. I hope these remedy your situation, as after about 2 days of trying everything else, these two solutions solved my problem.
