Ok, let me give a shot at this as well.
Now as for engines, they are all similar. Let's put this in perspective because it may give you a better "idea" on what is going on.
Like Akina said, the engine will only get you so far, the gearing and tire size also will make a difference.
Now, let's take two real life cars. A Chevelle with a 350 and a Chevelle with a 454. NOW, here's the major difference. If they are exactly the same except for the engine; here is what will go on.
First, the 454 will have the brute horsepower and be able to jump the line before the 350 model would even decide to accelerate. That is because of the horsepower behind the 454. Second, the 350 will be able to achieve a higher speed, not much, but a bit because of the RPMs. (Revolutions Per Minute). The average 454 will hit 4500 RPM and the average 350 will hit 5500 RPM. So, with the same gearing, the 454 will beat the 350 in acceleration, and the 350 will beat it in top speed.
Now let's hit another variable. Carberatours. Let's say you set a 2 barrel on the 454 and a 4 barrel on the 350. We won't get too technical, just enough to show the point. As for the 350, the horsepower will be greatened highly compared to a 2 barrel, with the 4 barrel. This means you can push more fuel and air into the motor, and that can increase the horsepower on the motor. Now, that 350 may be able to keep up with the 454 that's only running the 2 barrel off the line. But it will still be able to ditch it in top speed. Understand?
Now, let's get into the gearing. Take those same two cars, both with the 2 barrels and stuff. Now, let's take this into perspective. Higher gearing means higher speed and less torque, and acceleration. So let's put low gearing into the 350 model and high gearing in the 454. Chances will lean towards the 350 beating the 454 off the line because of the gearing. Lower gearing increases the acceleration, but there is a downside to this. The top speed will be decreased, because the RPM's haven't changed, the gearing has. And once that engine hits top speed, it won't go any faster. As for the 454, it will most definetly waste the 350 in top speed. The higher gearing took away from it's brute acceleration and torque and put it into top speed. I'm not going to say it still won't get up and move, but the gearing will decrease from it's acceleration, and give that back in it's top speed.
Two more things, but we'll mutate them into one paragraph. Air filters and exausts. Let's take two of the same chevelles, both with a 350 this time. Let's put some inky dinky exaust system on one, and a huge awesome exaust on the other. Let's also put a small low flowing air filter on the one with the miniture exaust. And let's put a Maxi-Flow on the one with the large exaust.
First the one with the "maxi-flow" can get more air hence allowing it to mix more fuel and get more horsepower. Now as for the exausts, it's got more flow through the exaust so it's going to be able to run easier, without backpressure. Don't take that serious for these engines though..
Now ideas to look for. First, quality in the engine. See what engine looks hot, has the best porting system out there to allow you to press the most fuel in the cylinder. That will give you the start for the horsepower. Now let's look at carbs. Get the best carb out there. Get something able to mix and add fuel PERFECT to the motor you chose. Get a GOOD quality air filter. The more air you can pull the better, specially when you're wanting to suck down as much fuel for horsepower as you can. And last, I may have confused you earlier, but here is another important factor. The exaust. A 350 doesn't run a "tuned" exaust like these motors do. So what you need is a well tuned exaust for the motor you chose. Get one that gives a broad powerband, or one that makes the engine give some excellent torque. That's up to you. Just remember the torque will give you acceleration, and the broad powerbands will give you more power when your on the throttle hard.
Hope this helps you understand a little better. If you have any questions, just ask.
