Well I have put about 2.5 gallons through the stock .21bb on my Savage. For the first 10 tanks it ran fine without any stalls and I completed the tanks. After about 10 tanks I noticed that the engine would run fine for the first minute or 2 then it would start getting really hot and then vapour locking the carb. I then have to wait 15-20 minutes for a cool down until I can start her again.
I have done the following to try and fix the problem, cleaned the fuel filter, change the fuel line, seal the tank, apply new o rings on the tank, add the duel tank modification, seal the backplate, seal the HS needle, clean the pipe, seal the carb and nothing seems to work. I have also taken apart the HS needle to see if there was blockage and theres none.
Also I'm not running lean cause I did a test today and ran it so rich that it will not hit 2nd and it wont hit High Rpms. It will run fine that way at temps around 270. If I lean it out a little bit it will overheat. My HS needle settings are around 4 1/2 turns right now any farther and it will lean out.
I'm running 15% nitro and 20% oil with an O.S. A3 plug.
Any advice Savage experts?
Steve
Steve
