engine off
avelciario
Hello guys, I tried my LRP zr30 spec2 on my buggy today. I've notice that if I run it for just 5mins it sudden dies, the temp is only playing on 220-230. Its jjust like no fuell coming to the engine or to the fuel lines. But I've check the glow plug there's some wet of fuel. Thanks in advance.
My guess....your LSN is too rich. Lean it out a little bit. You may also need to richen your HSN. Sounds like it might be loading up on you and stalling due to too much fuel in the crankcase.
Without hearing it run...it's very hard to say though. This is just a guess!
Yap, that's why when I reach my room I try to adjust the lsn a little bit leaner 1/8 turn and my hsn 1/4 turn (base on 360deg 1 full turn). And I will try it again tomorrow cause its dark already. I will let you know. Thanks for the help.
Motogod- Yes I've tried yesterday night I lean a little bit the lsn and make a little bit rich the hsn and it runs fine but 1 tank runs out very fast, its ok I understand because I had a big engine for a buggy.
Thanks...
