I posted this over on SC but I need answers/suggestions quick so here goes....
My 4.6 was on it's 8th tank when it shut down. I had already ran 3 tanks through it up and down the street today, I pulled up to a curb, blipped the throttle and get high centered, I blip it again and it dies.
Here's where it gets wierd. I go over to re-start and it and it has no compression, I notice fuel dripping from the exhaust and from under the truck. When I take a closer look to see where this other dripping is coming from I find it dripping from behind the flywheel. knowing something is not right I pack up and head back to the house for a better look. I get it home and give it another pull and now it has compression I pulled the plug out and the piston is moving (what a relief). I didn't try to re-start it because of the leak I saw behind the flywheel still had me spooked....What just happened and what should I do to troubleshoot?
BTW...temp outside was 39 deg / highest engine temp was 221 and still running rich with a nice size blue smoke trail at all RPM's.
