Electronics meltdown
@WickedFog ‘s suggested method is not bad, and it eliminates the extra battery. There are pros and cons, but either method works well. I’m using both methods in different rigs.
That said, I would disagree that servo performance drops off as the LiPo is drawn down. I’m not saying it doesn’t, but the performance difference is so negligible as to not be noticed at all. I’m running direct powered servos on my 1/5 rigs, and one of those servos is pulling over 11 amps at max stall on a 3s LiPo. That’s in a DBXL-E. The battery I’m using lasts for three propulsion packs (three runs) with no significant loss of performance before my voltage alarm goes off.
Wicked Fog’s BEC method (clip the ESC’s power wire where it goes into the receiver, solder the input voltage leads from the UBEC directly onto the ESC’s battery inputs, and plug the UBEC, set to 8.4v, into any unused receiver port to power everything) is a very easy “set it and forget it” method, and your servo will operate on a consistent 8.4v. Easy peasy.
The process of direct powering a servo with a dedicated battery is a direct plug and play, no soldering, but you do have the care and feeding of an extra battery to contend with. And your servo will be happier running on a clean, non-digitally processed power supply.
Either approach is fine. And people will also debate this until the cows come home. Different strokes. The reality is that you’ll probably never be able to tell the difference between either setup in a real-world scenario. Choose one, go forth, and enjoy your rig. Happy bashing, man!
I'd use the external UBEC. Just wire it to the main lead of your esc and call it a day.
I run a promodeler DS505BLHV in my maxx 4s with a max6v3 in it I run on 6S. The DS505BLHV is less power hungry than the reefs your using. I have it wired to a castle 10A UBEC. My fans/receiver are powered by the esc's built in BEC. It's not to hard to setup that way, just have to do some decent wire management. I even went so far as to decase my receiver, resolder the cap and grind the circuit board down a bit on my castle 10A so I could cram it all in the waterproof receiver box. lol!
My buddy has the same max6v3 in his arrma fire team and I installed the same UBEC you have to power the DS505BLHV he bought for that. I wired it up the same way. Both of them drive the servo just fine. I run mine at 7.4V though, it's still far more power/speed than I can use. I can't recall if he has his at 7.4 or 8.4, either way, it throws the tires around standing still on grass without batting an eye. With his UBEC, we stock it to the top of the receiver box I think. He's awful at wire management, but I had it all buttoned up nice when it left my house. It's probably a tangled mess by now.
With the reefs, your nearing the limit of the Firma160's BEC (8Amps). Add in fans and the receiver and your pushing it pretty good.
I was trying to find that Firma's BEC amperage, without any luck. But I figured it was around 8A. Where did you find that info?
Thanks, much appreciated , I think since I already have the UBEC I will go with that method for now until I can get a harness and I’ll try that method as well. I can do both plus I had all the connector tools and hardware so can change it up at will. I can get ‘er going with the equipment I have now so I’ll start there.
It's on spektrums firma160 v2 page, in specs:
https://www.spektrumrc.com/product/...smart-esc-v2-3s---8s-dual-ic5/SPMXSE2160.html
