e clips
HSPGuy2190
Gold Coast
  1. Racing
whats the easyist way to remove then and install em i saw a e clip gizmo on ebay for $20 but is there an easy way ? needle nose plyers ? or sumthing
I personally use needle nose like you mentioned.. Very easy, for removing the clip just rest one part of the needle nose on the shaft its clipped to. Then the other half just pinch the plyers on one end of the clip and usually it will just pop right off. But make sure you have your finger atleast resting on it so it doesn't fling away. Then for putting it back on i just almost do the same thing but with the clip in place put one end on the shaft like before but this time put the other end on the very back of the clip in the middle and squeeze.
I've been doing it that way for years with no issues. Special tools for that type of stuff to me is just not even really worth the money to me.. its a simple process.
when you remove them put your finger in front of it and make sure the way it will pop off is down, so you dont shoot it, believe me, if you shoot those things, game over, your have to buy more, their not expensive at all, but a hassle, trust me, if it shoots, your NEVER finding it!
