dual disk brakes
the 2 screws holding your pads and such on, just back them out like 1/8 to 1/4 of a turn
thanks but still doing it, almost unscrewed it aand it still ringing... is there something I'm doing wrong or what?:gulp:
:OMG: When i push it...ringing sound and when i push it and brake... sounds like it grinding something...bad sound !!!
nevermind i guess i put the disks the wrong way ! cuz now it brake a-1 and its not ringing to much!!!
OOOH YA !!
A little ringing is normal; there's a metal to metal contact going on there. It's perfectly normal, and will diminish as the brakes wear in.
how did u set the brakes up? shouldnt be any griding.
brake bar/pad disc brake bar disc brake bar/pad
brake bar is not the true name for the things, but god i can't think of the right name right now
Not grinding anymore!,just a little ringing...i dont know if it was because i had the disks the wrong way but i just turned them around and BINGO !! Should of look at the pic on the instruction manual a lil bit better...SORRY my bad !:shy:
And its pad/brake bar(the last part) i guess ! And the word you could'nt think of...is it SHOE ???
YEP !!! Another prob.!! just came back from bashing a bit, and i realise that one of my disk came off of the thing with 5 sides(forgot name right now) !:8-0: (did not check if it damaged anything)HOPE NOT !!!Are the screws supposed to be thighten all the way ? And could it be affect the running of the truck cuz (before) when i was playing with it i was pressing on the gaz and suddenly it swerve and almost ran straight in a parked car...:opps:
:depress: I've got a worst news now....my brake hub screw is missing(that would explain that the pshyco swerving) and i dont know if i screwed up something in the tranny?!? And do we put treadlock on the small screw?, man i hope that there is still treads on the brake hub...but gonna check when i wake up GOOD NIGHT !!!
You can threadlock the grub "post" screw (the one that holds the outdrive cup onto the transmission) - in fact, I recommend that you do, as well as tightening it down as tight as you can get it. The blue stuff is more than sufficient.
The hex thing that the brakes ride on is actually called a "brake hub". Wierd name, but that's what they call 'em. If your brakes are assembled properly, and the brake hub/outdrive is properly installed, the discs should never come off the hub (unless the two screws that hold the shoe-bars to the transmission come loose).
Have you ever Heard about this grub post screw comming off like that...and do you think it damages anything from your opinion...?
I have seen it come loose. It's not common, but it can happen. It shouldn't have damaged anything, provided you caught it in time.
