diffs
  • Thread starter Thread starter tannera
  • Start date Start date
T
tannera
Guest
i just done the 4 spider diff mod but when i push the truck it dosen't roll like it did before i done the diffs it's like the breaks are on i bit but there not.
and it jams up a bit when lets off and jams up again i have put 7000w/t in both is this normal?
Putting oil in the diffs and the 4-spider mod shouldn't make it roll any different, at least not in a straight line.
What else did you replace? Diff cases? Bearings? Diff cups? Diff cup gaskets?
Are you certain it isn't the brakes dragging? Is the gear mesh between the CB/spur the same (did you remove the engine)? Did you grease the ring/pinion gears in the diff?
i found out what is was i still had to mesh my gears and that's what was stoping it. also i had put to much oil in the front diff.
