Jeep said:I was thinking heavy on the middle diff, a lil lighter on front compared to middle and a lil lighter on rear as compared to front. Buit I could be totally off.
Jeep
jetmechG550 said:I think most of the Team X-Ray guys have been running 5-5-3. Their setup sheets are posted.
Don't you mean:vbgagnon said:If you like a loose rear end make your rear diff oil higher, if you want a rear that tracks well go with a light oil.
jon2 said:Don't you mean:
Loose rear end, use lighter weight diff fluid and higher in the front
High traction, use Heavier weight diff fluid maybe an equal amount in the front?
