I have a LaTrax 1/18 4wd stadium super truck and the little plastic thing that connects the speed control to the battery fell off and I was wondering if there is like a replacement for it or any tips on how to fix it
You should be able to lift up the main power bars in the connector from the other side, then push them out, resolder and pop them back in. They push out where the wires solder to them.
They will plug into the ID type connectors without issue. My ERBE and stampede both had ID male connectors on them, but my packs all had the older style TRX connectors like those in the link. They plugged in fine.
You can repair them as olds has stated with no harm. just remember to cut the wires b4 repair.. and slide them thru the back of the plug b4 you solder them on again.make sure you know what side what wire goes on
