De/Install tires?
Bansh88
San Diego
I have a bunch of extra wheels and tires that came with an Inferno I bought. I tried removing one old tire and it proved challenging. I was able to remove most of the rubber from one side. the other side appears to me more glued in and havent even given it a whirl yet.
Is there a method to remove the remaining rubber? Even if I could, how the hell am I supposed to squeez a tire back into these things?!
The usual method is to either boil or bake the tires to loosen the glue and allow them to be removed from the rim. Personally I prefer beadlocks and use them on almost everything I run. Screws beat glue IMO.
Any trick or heating to put on new ones?
Glue? Super glue works, I've been told.
Beadlocks would be nice but I'm just starting off.
The rims need to be clean where the tire beads mount to the rim. Then you want to use a good thin CA Glue to glue the bead to the rim.
You can actually use Acetone and let them soak for about a day. It would require alot of it but after a days soaking the old tires fall right off and the rims are usually sparkling and looking brand new. Might wanna keep it covered and well ventilated
i second the acetone, put the wheels in a bucket with a lid fill the remaining void with some aquariam rocks and fill with acetone covering wheels completely, be sure to cover bucket acetone evaporates quick.
Acetone ruins the foams. Not directly, but causes them to be ruined. That said, having the beads submerged in acetone for 8+ hours will dissolve all the glue and the tire will practically fall right off. It ruins the foams because it liquifies the glue and the foams soak up the glue/acetone, then when they dry, they become hard as a rock.
I've never bothered to try removing buggy tires. Rims are fairly cheap and it's not really worth the hassle IMHO. If your just a basher, you can find sets of wheels/tires on ebay pretty cheaply.
Regardless, I proffer the baking method. But, as noted, I never used the method on buggy tires/rims, only standard MT tires/rims.
Like was stated above if you can switch to beadlocks you will be a lot happier when it come to new tires and removing old one. plus you wont have the issue of tires coming unglued
I have never seen an authentic pair of beadlocks for a 1/8 rig, and I have browsed ALOT of beadlock wheels for my crawlers. Olds is spot on and I agree 100% baking the wheel/tire is the fastest cleanest way without fkn your stuff up.
I guess they no longer make them. They do say that the 3.2 will work on truggies with a 17mm hex.
