Sold / Found Custom Transmitter grip.
Status
Not open for further replies.
Greywolf74
I'M TO BLAME!
Lifetime Supporter!
Ohio
Custom made PPR transmitter grip. Only 4 ever made. Fits most standard radios. I know they fit the Flysky GT3B, The Futaba 4PL, The Airtronics M11. Other than those models Youd have to check the diameter of your TX wheel without the grip on it. The inner diameter of the grip is approx 41.5mm the are rubber and do stretch somewhat so as long as you're close to 41-43mm you shouldnt have a problem. Grip is Day-glo yellow and metallic black. Grip has a raised flame pattern the runs around the sides of the grip.
Price: $15 Shipped.
Maybe if it was Green & Gold.... (:
Sent from my Pipboy-3000 in the Capital Wasteland.
Hey greywolf, do you know if this will fit a spektrum dx3r pro? How grippy is it. The stock foam on mine moves in and out and is irritating when your racing.
as long as its not loose around the wheel its pretty grippy. Youd have to measure your TX wheel without the foam on it...IDK if it will fit that TX or not right off the top of my head. Never had that one. I do believe they fit most spektrum radios but I'm not 100% certain.
I would go ahead and measure just to make sure.
Ok ill check it when I can. Might take me awhile. Thanks for the fast response bud.
Status
