ok, maybe we're talking about different things here but you say " you cannot have the window of the crank open while the piston is traveling back down the bore of the sleeve" but isn't 50 or 60 degrees of window timing ATDC when the piston is traveling back down the bore of the sleeve? when your talking induction timing ya should mention ABDC & ATDC & duration to those who might not understand. overlap comes in ATDC when the piston is pushed back down the sleeve by the igniting of the charge & the side intake & boost ports open before the exh. opens thus helping scavage the exh, although a good bit of the new charge is waisted through the exh. even though the reverse pressure wave in the exh. does push some of the charge back in (supercharging) :mex:
