Couple of noob questions
lucky19
midland, Texas
1. I have a hpi rs4. Is the rs4 2, 3 or evo compatible in parts?
2. Instructions say something about a receiver battery pack, Whats a good on to recommend???
3. I have a 2 channel receiver were do i put this thing at?? I mean do i tape it to the top and it has a green wire coming out the side is that the antenna ?
4. The ends of the switch and both servos go were??? I'm guessing the 2 ch rec. but dont seem to fit in the slots.
5. Just ordered my fuel tank, and was wondering how does one start this bad boy??
TIA:yes:
1. I believe some parts are, some are not.
2. I would go with a rechargeable battery pack from your LHS.
3. If there isn't a place to put it or a box to put it in, you probably will have to double-sided tape it somewhere.
4. The switch goes into the port on the receiver that says BAT/DSC or anything like that. From there you plug in the rechargeable battery pack into the other end of the switch. The servos go into channel 1 and channel 2. If the servos don't fit you may need to use an Xacto knife to shave it down to fit.
5. Put in the fuel lines and pull on the pull start/ put it onto the starter box/ put the roto start into the backplate.
? #2 Dont have a LHS and will have to find one on ebay will any do?
OK how about that green wire in ? 3 is that the antenna? Forgot to mention, on the receiver their is a plug in the middle top. Whats it go to?
On the switch, the black connection goes to which servo fuel or steering? (I'm guessing black on black)
Also ? # 5
Hows this starter box thing work? I also have this big ass battery, does that go along with the sarter box?
2. Yeah you can find one anywhere, FastEddy sells some. teamfasteddy.com
The green wire is the antenna. The plug in the middle top is where you plug in the switch.
The switch goes to the battery pack.
5. You put the car on top of it, you push down on the car and it'll make the flywheel spin. If you're talking about a gel battery then that'll work.
