Cooling Fan (pic intensive)
You know how fast it would kill the batteries and radio if he had the fan attached to that power?! Also, I highly doubt that 6v is going to be better than 9v in this application.
i see you guess are talking about a fan i have two on my cen ct4s is thereanyn way you could drill and tap small hole where your fuel line is if you could make a few brakets and make a new carb intake and put a filter further up like a cold air intake but make it your self. then you can have your fan infront of the motor under the body. or make two brakets off each side of your car out of aluminum and run them in front of your motor then you can add two fans like i did.
tim
i know the whole point here is to be crazy and try stuff out and have fun but..
just wondering if this isnt counterproductive... the whole lean / rich / heat thing is a check and balance and runing a fan will throw that off so...best case is the fan works great temps are down so you lean it out till the motor doesn't get the oil it needs and POOF
or maybe I'm talkin out my a$$.
considerin those things actually push far less air than their rating, i dont see u gettin anywhere w/it, but nice try though. those things only push 6cfm of air as opposed 2 their ratings (which manufs say are much higher) in every pc hardware review.
keep pluggin, i'm workin on using a peltier that u can plug into a power source and warm up the block b4 u startup. especially insterestin on cold days.
-Ult
hey maybe nextime you can make a piece that fixed the fan to the motor air intake and make a blower or sompin. Has anyone tried to get like a little air tank and filled it with Nos and injected it into the motor or sompin and made it work?
if not i can still dream
