comp benchmarking tests
Blah420
this was done with 3dmark 05 lets see what you guys got
System Configuration
General Information
Operating System Microsoft Windows XP
DirectX Version 9.0c
Mobo Manufacturer Intel Corporation
Mobo Model D925XECV2
AGP Rates (Current/Available) 0x /
CPU Intel Pentium 4 3200 MHz
FSB 200 MHz
Memory 1022 MB
Display Information
Graphics Chipset ATI RADEON X800 PRO
Driver Name RADEON X800 PRO (Omega 2.6.05a)
Driver Version 6.14.10.6505
Driver Status WHQL - FM Approved
Video Memory 256 MB
Core Clock 472 MHz
Memory Clock 452 MHz
Benchmark Settings
Program Version 3DMark05 Revision 2 Build 0
Resolution 1024x768@32 bit
Anti-Aliasing None
Texture Filtering Optimal
Vertex Shader Profile 2_0
Pixel Shader Profile 2_b
Force Full Precision Off
Disable DST Off
Disable Post-processing Off
Force Software Vertex Shaders Off
Color Mipmaps Off
Repeat Count Off
Main Test Results
3DMark Score 4642 3DMarks
CPU Score 4565 CPUMarks
Detailed Test Results
Game Tests
GT1 - Return To Proxycon 21.4 fps
GT2 - Firefly Forest 13.0 fps
GT3 - Canyon Flight 23.1 fps
CPU Tests
CPU Test 1 2.4 fps
CPU Test 2 3.9 fps
I used to use Mad Onion too when I was heavy into the 3d gaming stuff. I don't do online PC game anymore. I just play xbox with my kids.
This PC I'm on has a 1ghz athlon CPU and a voodoo3 graphics card I think. 133mhz RAM I think too. It's aging, but It does what I need fine.
does anybody know why my fsb is only running at 200mhz
If you're running stock speeds on your processor, and it's a 800 mhz fsb, It's going to show only 200 mhz. The 800 mhz is achieved by using a "quad-pumped" bus as they call it. It's all thanks to ddr and the way it's accessed.... or something like that.
I'm depressed... my mobo took a dump on me last night........... I gotta get it all straightened out... funny that My 2.4c is fine, and I had it overclocked to 3.24 ghz... This makes the first motherboard I've ever lost to overclocking. When I get it all rma'ed and straightened out, I'll run pcmark and tell ya what I can do.
that first test was all stock,I'm gonna start tweaking things abit tomorrow if i get a chance to.so far pci express its pretty tight poop
