combination
abs
RCTalk Qualifier
mumbai
my cb is 19t/26. which gear should i use to match with this type of cb.
well the 26 will give u move speed but the 19 will give u more pulling compacity/ driving up steep hills
thanks for info, but i need to know what combination spur should i use? eg i have Cb with a low gear 19t and high gear 26t. will 63 spur and 70 sper mesh correctly or i need a different spur gear for it.
thks i advance.
19/26 works with stock spurs, which is 63/70. As long as the CB pinions have a difference of 7, they work with stock spurs.
I'm about to install 21/28 in mine... I run smaller/lighter tires, so the extra teeth on the pinion more than make up for the difference.
I ran 19/26 on mine (with stock spurs) and it wasn't enough speed with my setup. I'm guessing my engine will pull the taller gearing just fine though. As long as I stick with smaller/lighter tires. Even so, I'm sure it will give my teflon shoes a workout!
