I was running a 17t clutch with a 36t spur - forward only diff and wide ratio differential. I have destroyed one plastic spur in about 200 metres of throttle on. It just stripped the teeth clean off. I then put on a hardened steel spur gear (integy). That one lasted about 2 weeks then shattered yesterday when I was giving it some full throttle workout without jumps - just flat work. Basically the teeth are getting so much force form acceleration and then braking that I think the ends of the teeth are being slowly fatigued. All the setup is right and I've checked the endplay and alignment with vernier calipers. is there any techies out there who may have some idea what to do in this case.
I've ordered some extra hard spurs from Robinson Racing - but the spur from Integy was also hardened. Maybe I need a completely different Clutch for this REVO truck. Anyone know of engine hopups that could handle this problem let me know. Engine is RB 9 port.
