Cheapest way
IMO the Ofna tank. Its 125cc instead of 150, but it works. Just drill the mount holes on the tank out a bit more for the posts to fit and put both tank mounts on the outside of the TVPs. $15 fix and looks factory.
u can fix it for free like battyone said
just tune it to were its runnin rich for the first half of the tank
ur suppose to let them warm up before runnin hard anyway
Just add more fuel line to the muffler end for the added (hold) presure to the line just make sure some point of the line is higher than the carb and it's a doller fix .. All of the above will work .. Good luck with the choice you go with
I went with the OFNA tank and made my own mounts out of steel rod stock. Have tried many fuel line tricks, but never fully solved the issue. Replacing the tank seems to be the only sure fire way to do so.
This is the one everyone goes with usually:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBM24&P=7
My rig with the OFNA tank:
I put a Ofna Ultra LX2 145CC tank I won on E-bay for 3 dollers on my XL and works great , any flat bottom tank should help if not fix the problem
this tank will be to long for your X this is more for a idea that any flat bottom tank that you can fit will help you fix the leaning prob
[/IMG]
[/IMG]
Yeah, you don't have that kind of real estate on a X. I used a tank similar to that when I had an HB extended savage (pre-xl conversion). Now I'm back to the 125cc tank... :(
