kx250ryder
I was going to buy a MRC Super Brain 969 Pro, but then I saw that this model (977) is only a little more. I heard that they fixed the issues with Li-Po too (although this doesn't matter much to me because I don't have any of those cells). My question though, is about the discharge feature.
I run 1/8th scale Nitro, so I have four different types of batteries:
2400 mah nimh AAs in my radio
1500 mah nimh receiver pack
7ah starter box battery
1200 mah Nicd sub C glow charger battery
If I am right, the NICD glow charger is the only one that should be discharged, correct? If so, is the 4 amp discharge cycle on this charger acceptable for this use? I know that these types of batteries are expected to get drained at about 20-30 amps in r/c electric car applications, and that you are supposed to discharge at rates similar to the rates seen in the application. So I figured this battery sees slower drain rates since it is used as a glow starter battery, and that this charger's lower discharge rate would be ok. Anyone know if this logic is correct?
If not, can anyone steer me to another charger that can PEAK AND DISCHARGE MULTIPLE BATTERIES of DIFFERENT TYPES at the SAME TIME with an EQUAL OR HIGHER DISCHARGE RATE THAN THIS CHARGER? (caplital letters represent required features).
