mamba max should work with everything.you have to watch what batterys ya runnin with what motor tho....like they say not to run a 7700 with a 3s and so on
So could you run the 1/8 mm esc with a 1/10 motor? I know that seems a bit stupid to ask but it would be a question that would be floating in my head for the longest time if I didn't ask.
Monster Max will work with all sensorless brushless motors from 1/18 thru 1/8 scale. Mamba Max will work with 1/18 thru 1/8 scale but will require use of external BEC/fan with anything greater than 3S lipo.
5700KV on 3S is fine for short high speed runs and proper gearing. For 1/10 scale motors, anytime you approach the 60K rpm mark keep your runs short in duration and watch your motor/esc temps.
