Shogun1122
RCTalk Racer
I have a savage 25 that i have added a Wasp .26 to. With the last couple of spur gears that i have gone through, i noticed the same problem occuring. The mesh between the cb/sg is off.
When the mesh is just right in one spot at others it is too tight. Then when you fix it, it is too loose at other spots. My first guess would be that the shaft comming out of the trans is bent, and my second guess would be that my crank is bent. But individualy they seem to spin true.
Here's the kicker, the spot where the binding happenes is inconsistant with either the revolution of the spur gear nor the clutch bell... go figure.
I have since added both a new spur gear and new clutch bell, and the problem continues. To fix the issue i have a compromised mesh that is both slightly tight and slightly loose at the same time, if that makes sense. Though this is a solution to a problem it does not seem to be the correct one. Has anyone else had this problem. Please Help.
