beason
Bash, Fix, Repeat..
i was running my savy sunday and noticed that every time i stoped running it, when i would go back there would be a rough spot on my spur.. upon closer examination i noticed it was a melted spot most were just little rough spots but one melted pretty bad.. i have the xtm 24.7 engine, carbon 3 shoe setup with 1.0 (black) springs and when i had it apart last i hit the cb with 150 grit sand paper to take the gloss off, after the run i looked again and it seemed the gloss was back so i sanded it again. i did notice though that i had forgot a shim and the inner bearing was setting against a bigger shim that would alow both inner and outer races to touch it. cb spins free but has almost no play in it..could this be the problem?? am i doing something wrong?? it didnt start till the 24.7 but i did the sanding at the same time and replaced the shoes and springs.. i temped the bell once and it was 167 deg..
