Castle Mamba X 8s acting up, no throttle
SpeedmaxX
Alright so I've hit a birck wall. My monster mamba x 8s has been nothing but a headache. Was working fine let it sit for a couple weeks waiting on gears. Installed and fired it up and it went to reversed throttle input. Next day esc went to a solid red light. Then it transitioned last night when my dad was messing around in the castle link app. Now its blinking and beeping... see attached video. Throttle trim is at 0 (SANWA M17 SUB T) not getting any throttle input it seems but servo works just fine. I've reset the castle settings to factory. Batteries are good.
Read the manual on how to calibrate the throttle. On most, you hold the program button down while powering on the ESC. Then you turn on the transmitter. Press the program button to calibrate neutral. Pull the trigger all the way back and hold, and press the program button to calibrate fwd, then move trigger to reverse and hold and press the button again. You then reboot the ESC. Not sure about your ESC, but the manual will say how.
Bro go on the Castle link on your laptop and reset it to factory settings or whatever that says back to default I had the same problem dude I did that and everything was fine
At first it was the data logs that were full and I did something and I can't remember what I did but long story short I went on the laptop set it back to default and everything worked fine and redid my settings and everything's good
Just did that and now it arms.. making progress but still not seeing throttle input it seems. Not able to calibrate or go into programming mode.
R your throttle and brake rate at 100
Make sure they are both at a hundred and then rebind then see what that does also make sure your data logs are cleared
Yes transmitter at 0 sub t and 100epa for both
Rebound still not seeing a throttle response it seems. Smh about to take it outside and use it as a target.
Sanwa m17 with a rx493 (rx and transmitter are good confirmed in my race buggy) even factory reset controller to triple check
have you another transmitter and receiver ?
try other transmitter and receiver, then it will bind.
i have one castle that binds to my nasty rtr radios only, not my professional futaba at all
R your data logs cleared. Also what's the color on the ESC when you got it on
And if you have a gyro that could be a problem too
Yellow light that beeps every so often. I've used this transmitter in the past with no issues.
Yeah that's the same problem I'm having. Except mine go through the chimes at start up but right before it arms it gives one really long beep and then nothing. No throttle. Was working fine... now nothing... I feel your pain. I have re-bound and recalibrate and charged everything. Going to reset everything to factory and see if that helps. I really like my castle motor but if this keeps happening it isn't worth the headache...
