Sold / Found Castle ESC/motor, Trenchers, and 1/10 shocks!!!!
Status
Not open for further replies.
Littlemotor
😈Primobilt.😈
Build Thread Contributor RC Showcase: 6
PittsVegas, NC
Going through my stuff here at the LHS (Littlemotor’s Hobby Shop 😂), and unloading some items I’ll never use, what with running 1/8 off-road almost exclusively..
Castle Creations Sidewinder 3 Waterproof ESC, and Castle Creations 4600Kv sensored motor. These are literally like new, and have less than one pack through them both.
$100—-***SOLD!***
Pro-Line Trenchers 2.2 wrapped over Pro-Line Desparado wheels w/12mm hex. These were LITERALLY installed on the vehicle, ran about 80ft, and removed. The serrations from the wheel nut is imprinted one time, and not over torqued. The rubber flash from the production process is still visible down the centers of all (4). Not a single crack in the glue job, or any “haze”/fogginess what so ever. Literally BRAND NEW. I did not even clean them up as I am not one to hide shiit, or dress an item up to make it look better than it is for a sale.
$45—-***SOLD!***
Pro-Line PowerStroke 1/10 SCT Rear Shocks
These are in perfect working order, full of fluid, and no mechanical issues to speak of. There IS very slight missing powder coat on the face of one of the shock caps due to 1/10 not utilizing plastic bushings between the cap orifice, and the standoff. This is absolutely normal, and is not at all visible when installed. Also, these have been very popular shocks for 1/10 vehicles for a lonnnnng time. Please use you melon, and do NOT attempt to run these on a 1/8 buggy (unless you hate having straight shock shafts 🙄). These are $61 on Horizon currently. Again-great shape, and zero wear. Even the pivot balls exhibit ZERO slop within the shock end.
$40—-***SOLD!***
I'll ask the pros here. Is there a difference between need and want in the RC world? 🤔😬
Are those PL Trenchers guessing those are stadium truck ones? I'll PM you later about that unless someone else needs them more then me
In my vast personal experience, and homework, it seems to me that IN RC SPECIFICALLY; “want” in fact, actually EQUALS “need”… Your results may vary, however…🤷🏻‍♂️😅
These are buggy wheel size, and will also fit mini-revo 16th MT, as well as the Grom’s I do believe.
1/10 stadium truck wheels are a substantially wider 2.2 wheel.
how much for them?
Ohh there buggy size. Ok yea I don't need them. Unless someone can fact check that they can fit a B74 but looks too deep of a offset
I can fact check for you sir. The offset is indeed different than 2wd/4wd 1/10 buggy rear. They’d be wider than factory. 🍻
If these photos were shot with the products on a mirror with a light ground fog and some gratuitous cleavage behind said product, these items would already be gone, you really need to work on your sales technique. 🤔
I can use them. Perfect on a mid
Shiiiiiiit man, they JUST sold as you were typing that lol. I was marking them in the OP at the same time just after the transaction was occurring via PM’s… 😅
I had thought about that…😅
I gotta stop slippin’ so bad, I don’t wanna catch the ban stick! 🤣
Its ok if it falls thru lmk.
Mrs Certified isn't super impressed with my rc spending at the moment anyways . 🤕
Absolutely-and I can surely relate! There a fair amount going on “behind the curtain” at the Littlemotor Compound, that shall be revealed soon enough lol.. 😈🤩
That does it! I need better curtains! 🤣
I am so blind lmao I did not see that.
You’re good bro-just eat more carrots! -Especially at your age! I’d tell ya why-but this is a G-rated forum after all..😂
Status
