mypoorbrain
Now that I have your attention... I was bashing around last night and tore the driveshaft out of my truck... looking at doing the HPI/REVO setup for the rear center shaft, but thats another post.
During teardown I decided I would fill my diff a heavier wt oil to help with off roading and found that a bearing had grenaded in the carrier. Now i don't know what size it is because it was destroyed and almost stripped the ring/pinion gear. The bearing in question is the inner bearing on the pinion shaft.
Does any one know what size this bearing is and how it fits over the shaft of the pinion gear? If its the same as the other one I don't see how it will fit on there...
