Oxyacetylene
I just removed the stock S-25 engine to clean it up a bit. When I did I noticed that when the carb is fully closed it doesn't appear that the spring is even touching the linkage point. So if the spring isn't pulling it fully closed is there any need for it? I have redone the throttle linkage setup and adjusted it so that neutral servo position has the slide closed. Is this why some people move that spring to pull on the pivot bracket instead of being on the carb itself?
