Good smoke means the HSN is not too lean. It's possible that it's too rich.
What kind of temp is the motor running at? Usually if you're bogging down on take off, the LSN is too rich, you can try the pinch test to check the LSN setting. Get the motor warmed up, make a couple WOT passes to clear out any extra fuel. Bring it in and pinch the fuel line closed, the engine should rev up then die in 3-5 seconds. Any sooner and you're too lean, any longer and it's too rich on the LSN.
Okay, i have a question, you might think its stupid butt here goes......with the pinch test, how could that be accurate, becuase say if you pinch closer to the carb, it would take less to shutt off, if you pinch farther away it would take more time shut off right?
I thought the same thing, tried it both ways and it shuts off at the same 'count'. The reason, I'm assuming, is because once you pinch it, you are stopping the flow of fuel all together. It's not pulling the fuel from the point you pinch, the fuel will actually stay in the line, it's burning what fuel is in the engine. I think when you do it, what happens is you cut off the vacuum created by the engine and the exhaust feed to the fuel tank. Try it and you'll notice that no matter where you pinch, the line stays full of fuel, both before and after the pinch point.
I think that's why you can tell how your LSN is set, because that will give you a ballpark idea of how much fuel is in the engine when the line is pinched. I don't use this technique anymore, I adjust the LSN based on how the rig takes off from a stop.
