carb question?
knemo77
RCTalk Racer
so if my carb is on there straight the linkage rubs against the rubber making it stick open.
can i turn the carb or does it have to be perfectly straight?
ok the carb right now is perpendicular to the engine and i am wondering if i can turn the side with the fuel line upwards getting more clearance for the ball-joint on the right side of the carb.....i hope this helps if not i will post pics in the mornin.
You can turn the carb in any direction that suits you. I recommend that it is firmly seated and sealed, and that the throttle is positioned so that its movement and control of that movement is not impeded.
One of the first mods most people do is a carb flip. They turn the carb so that the throttle arm is on the right side of the truck vice the left side (this is for those with a rotary carb...some with slide carbs do this also).
