carb issue's
saltykillswitch
Utah
I was 2.5 t-maxx when or started to run like crap. The idle was low and was having a hard time keeping it from dieing. Tried to bump the idle up and I couldn't get it to change. Pulled the Fourier l filter off and found the throttle slide is all jacked up abs note closing and moving in its bore sideways. Is this a problem with these? I just ordered a 3.3 to replace the 2.5trx am I gunna have the same problem again or should I get a different carb?
perhaps you could read your post before posting lol.
the trx carbs are painful at times but the parts are cheap and easy to get ,from what I can decipher it would be easier to replace the carb as something has stripped ,I would go with a losi 3.4 carb and never look back ,they make the trx mills so much asier to tune.
Yeah the spelling was really bad sorry guys. I ain't sure what the problem with it is the slide is just all messed up and sliding sideways and binding
9
3K
EJMOPAR70
EJMOPAR70
normrdz300
8
normrdz300
normrdz300
R
8
RELIC01
R
J
jknowles123
J
normrdz300
4
3K
normrdz300
normrdz300
