can't get WOT
chaos2767
Menifee, Ca
Hey guys, having an issue with the Picco.21 in my Revo. I can't get the servo to open the throttle wide open, it stops just short of 3/4 open. I moved the throttle linkage around to see if I could get it to open more but it does not work. The servo just does not turn far enough. Need a little assistance on what I may be doing wrong.
Did it work fine before? Servo could be dying.
Otherwise, it's either an issue with your end point adjustments, or you need to attach the linkage pivot further out on the servo horn (or get a longer horn)
Is this a new occurrence? Or how long has it been doing this?
I figured it out, I just needed to adjust the linkages back a little further and set the idle on the motor. Its all good now, it is a brand new spectrum 6080 servo and new Picco.21 motor! All good now!:D
