Hi, i am trying to get the carb off of a losi m26ss and i can't get it. i got the nut off of the pin but I'm trying to get the pin out and its not comming any tips??? thanks
not to sure how it is made ..but i know the ones i have , the pin wont come out unless you take the carb off ....if you can twist ( move ) the carb a bit , it should come right out ...then the pin will come out ..
There's a groove in the pin that the carb neck slides down against. When you tighten the nut, the other side of that groove pulls the carb tight. You need to wiggle and move the pin till you feel the spot of least resistance, then wiggle the carb out of the neck.
Normally what I do is loosen the pinch bolt @ 3/4 of the way and then tap the bolt head so the opposite side pops out of the slot. Then pull out both pieces and the carb will slide right out with no resistance.
