Hi all,
So I bought a Revo 3.3 a few months back and put a gallon of 33% nitro fuel through it before it started overheating viciously. I could get the running temps down to the 260-280 F range, but only if the mixture was so rich that it didn't even have enough power to make 2nd gear on a long flat surface. I noticed fuel accumulation on my back 2 shocks, and assumed it was the front bearing starting to leak, as I read they seem to go out on the TRX 3.3's fairly early.
So I bought an OS 21TM (I know I could have changed the bearing on the trx, but I wanted the OS anyway so I figured I'd just go for it) I took the OS out of the box and sealed the base of the carb with black high temp silicone RTV just to be on the safe side.
I started the break-in for the OS with byron's gen2 25% nitro, 11% lubrication fuel, and the glowplug that was included. After about 10 minutes of idling I noticed there wasn't much smoke coming out of the exhaust. I thought that was strange so I checked the temperature: 411 F! I killed it right away, it shut off almost as soon as I pinched the fuel hose.
The manual states that it comes with factory set needle settings for breaking it in, so I never messed with them.
I did a leak check on the tank, it seems to hold pressure fine. No bubbles underwater. So I installed all new fuel lines and zip tied the bases in place.
After letting it sit overnight I tried to run it again. It climbed to 300 in a matter of minutes, so I shut it off again. I noticed when I was trying to start it that the engine seemed to be having trouble pulling fuel through the hose. I had to place my finger over the exhaust and turn it with the easystart for a good 10 seconds just to get the fuel to the carb.
I'm at a loss for what to do next. Thanks for any advice.
